how can you tell the difference between a 4.8 and 5.3 motor
Old 05-06-2011, 07:54 PM
billyflantos's Avatar
Default how can you tell the difference between a 4.8 and 5.3 motor
any special id markings or something?
Old 05-06-2011, 09:36 PM
s10jake's Avatar
Yeah id like to know as well
Old 05-06-2011, 09:44 PM
wantsum410's Avatar
The 4.8 & the 5.3 are identical on the outside,the only way to tell the dif. is the tops of the pistons .There is a new book you can get at Amazon on How To Swap a LS Motor into anything which has alot of good info in it ,pinouts , ect.
Old 05-06-2011, 10:57 PM
Andy1's Avatar
The 4.8 has flat top pistons, 5.3 has dished pistons. I know of no other way to tell them apart; both have 4.8/5.3 cast into the back of the block, so the pistons are the only way to tell.
Andy1
Old 05-07-2011, 07:35 AM
flame's Avatar
Yep pull a spark plug out and turn the crank till you can see the top of the piston
Old 05-07-2011, 01:16 PM
rickjamesCC's Avatar
The experience that I have with the engines is that the back of the block has a 4.8 and 5.3 marking the one that it is, is usually marked with white marking and like they said if you really want to know pull a spark plug!
Old 05-07-2011, 01:37 PM
firstgenguy's Avatar
5.3 piston looks like this. It will have a slight dish and a 4.8 will be flat across.
Old 05-08-2011, 01:11 AM
Slick87Rush's Avatar
you guys are correct about the 5.3 and the 4.8 being the same block. usually there is a paint marking on the front and the back.
Old 05-08-2011, 08:02 AM
lovescamaros28's Avatar
The eighth letter of the VIN of the vehicle that the engine came out of. Possibly the engine I.D. number(different from casting #) at the front of the block also. That is the only other ways I can imagine.
Old 05-08-2011, 11:54 PM
Pocket's Avatar
Pull the pan and check the casting number on the crank
Later 5.3's are also flat tops, so a boroscope cant give a definite answer. Using a rod down a plug hole to measure stroke never worked for me
Old 04-30-2012, 06:12 AM
1988montecarloss's Avatar
how can you tell the difference between a 6.0 and a 5.3/4.8?
Old 04-30-2012, 11:05 AM
brian.harmon1974's Avatar
6.0 has "6.0" cast on the front of the block in the same spot as it would say 4.8/5.3 on those blocks
Old 04-30-2012, 11:37 AM
94'BLKBRD's Avatar
4.8 and 5.3 engines have Head Gasket tabs that stick out and it says either 4.8 or 5.3 on it, if they are not broken off.
Old 04-30-2012, 11:56 AM
alexcoreas's Avatar
This is an 02 5.3 from an avalanche. So I was told
Old 04-30-2012, 12:10 PM
travisn's Avatar
Gross, I hope you got that for scrap weight
Old 04-30-2012, 12:19 PM
alexcoreas's Avatar
27k miles paid 750 for it. Still have to clean it.
So what's wrong with it?
Old 04-30-2012, 12:26 PM
97badass's Avatar
Looks like someone took a **** in every cylinder.
Old 04-30-2012, 12:39 PM
alexcoreas's Avatar
I thought that was just regular carbon buildups. How does everyone's bottom end look? I've seen many look like this.
Old 04-30-2012, 03:52 PM
Andy1's Avatar
VIN number, as mentioned earlier, is one way though it doesn't help for visual identification. IIRC, the 8th digit in the VIN, V for 4.8, and T for 5.3 for trucks except for the L33 (Z?). I'll stand corrected as this is all from memory.
Andy1
Old 04-30-2012, 06:31 PM
BOXCHEV's Avatar
Originally Posted by 97badass
looks like someone took a **** in every cylinder.
lmao..
Quick Reply: how can you tell the difference between a 4.8 and 5.3 motor
